Electric choke hook up >
Old 05-15-2023 | 08:55 AM
TomZ's Avatar
You really don't need the choke - I'd yank the assembly off the carbs and pull the choke plate and shaft - it's not needed. Mine will start, in 30 degree weather without a choke (emergency winterizing). They may complain a little at that temperature, but after about half a minute or so, they're good to go.
Also, as mentioned above, the reason not to use 12V from the coil is due to the use of ballast resistors - ballast resistors were used to drop voltage at the distributor in order to make points live. I don't think any of us here are using distributors with points so it's really no longer much of a consideration - Holley leaves it in the instructions to cover their arses.
Dump the choke.
TomZ is offline
Old 05-15-2023 | 10:50 AM
Knot 4 Me's Avatar
Dump the choke.
On Holley's go one better and mill the choke tower off too. Instant Dominators!
Knot 4 Me is offline
Old 05-15-2023 | 02:01 PM
TomZ's Avatar
Woohoo!!
TomZ is offline
Old 05-15-2023 | 07:07 PM
Thanks everyone for all the help. I will not be hooking up the chokes after all.
PQ290Enticer is offline
Old 05-16-2023 | 07:43 AM
I agree with no choke, also never enabled mine, however if you decide to proper voltage location is voltage sensor terminal on alternator.
GLENAMY 242SS is offline
Old 05-16-2023 | 07:51 AM
SB
Typically best Holley idle mixture screw setting is about 1/4 turn out (rich) from best warmed up idle in neutral .
Less finicky ‘cold starts’ and good putting in gear drivability when warm.
As always, Your results may vary.
Note: engines with even mild camshafts will enjoy more initial timing. Even a few degrees can make a world of difference.
SB is offline
Old 05-16-2023 | 07:59 AM
I switched to higher output single wire alternators a few years ago. Is there a location on this type of alternator for the choke connection? I have no idea what the initial timing is on my new engines but I know the total advance is 33 degrees. They start fine just cold blooded. Neither will idle cold below about 1700 rpm's.
Old 05-16-2023 | 08:10 AM
IDK I am not at home so cannot look at my spare.
Old 05-16-2023 | 12:46 PM
TomZ's Avatar
It'll be fine - I wouldn't even dick with the whole choke thing.
TomZ is offline
Old 05-16-2023 | 09:04 PM
Rookie's Avatar
That's a tuning issue. I'd find out what your timing is at idle and tune the carbs. (unless you're talking 45°F and below)
Rookie is offline
