Antifreeze vs. RV Antifreeze
I don’t have a pool, cause it’s friggin Wyoming, but I do have an rv. RV antifreeze is designed for plastic holding tanks. I don’t see why you couldn’t use it for a pool
Edit…
just went and found this for you
Edit…
Not sure abt pool anti-freeze but there's more than one type of pink RV anti-freeze. If it's going in a boat, you want to make sure it's the right stuff.
Pink anti-freeze contains denatured alcohol?
As noted, there are several types of "pink" antifreeze, some boat owners don't even bother to get the "right" stuff, lol! Basically if it says, "For Water Systems Only", that is what it means; don't use it for boat engines. If it has the little engine graphic on the container ALONG with all the water tank symbols, it's good for engines AND water systems. So if you're just talking RV WATER systems, it is the exact same stuff.
Baja 252 Islander
Baja 252 Islander
