Can you really regulate oil temp?
#51
I kind of agree with SB.
Looked at the thermostat manufacturers you have website.
Says the stabilization temp is the 215°, full flow 233°.
I guess their claim is the stabilization is where the temp is supposed to "hover" at with the element you have.
And they use the phrase "Typical Stabilization Temp".
So seems that is sort of where you are with the oil stats.
Your latest test though is hard to validate IMO because you didn't do any WOT runs with the stat bypassed as you did earlier when you said
So would it reach those temps with the stats bypassed and WOT?? I'd sure be hell trying.
And the dead horse, did you shoot the damn pan of both just to see what the IR gun is reading compared to what the gauges are reading?
When WOT it goes somewhere between 230 and 320.
#52
Took it out today to get the oil pan numbers after a WOT run. The port engine made it to about 210 degrees (no oil thermostat at all) and the starboard made it to 250-60 degrees(?) Improved Racing said it's not uncommon for the temps to go over the setting and then drop back and stabilize somewhere between the 215 and the 233 degree mark depending on your cooler etc. The WOT video is just for context so you know how long I ran it at WOT and it shows the temps on the gauges. The 2nd video is me trying my best to "shoot the pans" after that run. I don't know if makes much difference or not but I chose to leave them idling. I think I'm going to take "Rookies" advice and bypass the other thermostat too. Thanks for all the help.
#53
this is why I would like to know the temp after the cooler. if it is down around 210-220 then the cooler is working but the engine is generating too much heat due to tune or clearance in bearings. right now you know what the engine is making for oil heat but not whether it is because the heat is stacking up due to a lack of cooling or the engine itself is generating a ton of heat due to tight clearance or lean tune.
