500 Bulldog dimensional drawing wanted >
Old 06-14-2023 | 05:32 PM
Scott B's Avatar
Default 500 Bulldog dimensional drawing wanted
Search failed me, looking for the installation dimensional drawing for a Bulldog. Anyone got one they can share?
Scott B is offline
Old 06-15-2023 | 07:26 AM
Wally's Avatar
Were doomed!
I dont have the 500 bulldog specifically but here's the 454/502 setup dimensions that can get you fairly close,,,im sure specs like the exhaust width and overall length with acc on may be different, but the major items like motor mount locations etc will be the same....
File Type: pdf
-Wally
Wally is offline
Old 06-19-2023 | 06:04 AM
Scott B's Avatar
Thanks Wally, gives me something to work with! I'm using stainless marine exhaust so those dimensions re available, I';; mark this up and do some calculating
Scott B is offline
Old 06-19-2023 | 06:36 AM
SB
Bulldog used a tall deck block, right ?
SB is offline
Old 06-23-2023 | 10:22 PM
Scott B's Avatar
Correct.
541.9 CID
GM MK 4 tall deck (cast# 14044807)
Block clearance to accommodate 4.375” stroke
Siamese Bore, reinforced decks with blind head bolt holes.
Deck 10.2”
2 pc rear seal
Bore 4.44”
Stroke 4.375”
(With a factory recommended bore range 4.250’- 4.560” there is plenty of room for upgrades)
SCR 8.6:1
4340 Lunati crank
Piston is Wiseco (Merc part #)
Connecting rod is Manley +.400" / 6.535"
Dart Single Plane Intake Manifold
Crane Camshaft Specification Card
Part Number: 13H000036
Grind Number: H-240/329-2-10 T1.2
The cam rates on a 110*LSA, 5* advance
Lift .329” Lobe .559” Valve
Lift .340” Lobe .578” Valve
Specs:
@.0042"
................Opens..........Closes............. C/L...........Duration
Intake.....43.0 BTDC.....77.0 ABDC......105*..........300 °
Exhaust...88.0 BBDC.....42.0 ATDC......115*..........310 °
85* overlap
@.050"
................Opens...........Closes...........C/L.........Duration
Intake.....15.0 BTDC.....45.0 ABDC.....105*.........240 °
Exhaust...60.0 BBDC.....10.0 ATDC.....115*.........250 °
Camshaft Is Ground with .0012" Lobe Taper
Scott B is offline
