Sea Strainer best practice location >
Old 07-07-2023 | 02:43 PM
Default Sea Strainer best practice location
30ft Cobalt Condurre
BBCs with transmissions powering ASD6 Arneson drives.
The engines get pushed right up to the front firewall, blocking access to the sea strainers.
I've heard the best location for strainers...is high enough to fill them with water...but low enough the cover can be removed without flooding the hull.
Moving Moving them to the transom area, they'll have to be quite a bit higher than they are now. I was thinking of fabricating a mount that would enable an adjustable height...I'm not sure exactly where the waterline is going to end up.
Looking for some wisdom on how to approach this.
Art
Tartilla is offline
Old 07-07-2023 | 03:21 PM
Definitely install a valve on the inlet side of the strainer.
underpsi68 is offline
Old 07-07-2023 | 03:24 PM
Roger that, I have nice big stainless ball valves on the inlets.
With the relocation, I think they need to be supported better for sure.
On that note, what is the best water intake system on a hull water harvest?
Tartilla is offline
