Yes a 170 amp alternator will be a problem. In that case you need to use something that can handle the current and also change the wire from the alternator. Probably #4 to play it safe.
Originally Posted by Mbam
(Post 4873060)
From what I can see in the photo it looks like you are already using the right mounting point on the carb. Check your throttle to see if it has a cable attachment point closer to the pivot. What I have had to do for a fuse replacement in an emergency is use a couple wraps of 18ga solid copper wire inside the fuse assembly. It was enough to keep the batteries charged, of course it was only a 45A alternator.
| All times are GMT -5. The time now is 04:36 AM. |
