Converting EFI to Carb Gen IV 454 Gen V VI 502 >
Old 10-12-2023 | 03:28 AM
SB
I’ve done what TomZ has shown. With GM/Merc EST.
SB is offline
Old 10-12-2023 | 01:14 PM
TomZ's Avatar
Honestly, the simplest deal going. It just works.
TomZ is offline
Old 10-12-2023 | 11:01 PM
Originally Posted by TomZ
Keep the EST. You can buy the pig tail on Amazon for less than $20 or take what you need from the injection harness and splice (I went this route).
Diagram for the EST below. Ignore the 4-pin connector - you’ll no longer need to plug anything into it.
The distributor shown is for a MOPAR adaptation of the GM module so don’t worry about those. You’re interested in the + and C connections.
Set your total timing at 3k rpm. 32 degrees total is probably good on a stock iron-head 502.
thank you ! Ended up using the EST setup and it already sounds 1000x better
pouliotk2441 is offline
Old 10-13-2023 | 07:40 AM
the est,s work great and have a lot of initial timing and a very hot spark
boostbros is offline
Old 10-13-2023 | 12:25 PM
I saw in a few threads where people needed to leave the 4 wire plug in place, and wire in the shift interruptor wire to the reference/#3 pin on the module. Is this true?
Old 10-14-2023 | 04:44 AM
SB
Bravo’s don’t need shift interrupters….Alpha’s do.
SB is offline
Old 10-15-2023 | 01:37 PM
got it. Thank you! We got it running. It’s still acting up, doing the same issue it had before. (Huge thread I posted here a month or so ago). So idk what else it could be aside from a few charging wires.
