525sc overheating >
525sc overheating
525sc overheating
Old 09-15-2023 | 09:52 AM
Default 525sc overheating
So noticed it last week, temp gage was bouncing around, Thought the sender was bad replaced that, Then my alarm started going off, So as long as I kept it under 3k rpms not as bad so I limped it in, So thinking I may have chunked an impeller, I ordered a thermostat kit and also another impeller, Impeller looked fine switched it anyways, As so did the thermostat. So took every hose off of everything and there's plenty of water flow going everywhere, Ran the boat without a thermostat and it runs perfectly fine temps don't really move, once warm, What am I missing here where should I look, ? Also installed a strainer So I can make sure there's water flow, But also my water pressure went down to like 2 p s I,
Nfast is offline
Old 09-15-2023 | 10:04 AM
Take the hoses off the large heat exchanger. Flush backwards with hose. you should be able to look with a mirror inside to see if you have and weed blockage.
fossil fuel is offline
Old 09-15-2023 | 12:22 PM
Most likely an old school 525sc that is raw water cooled. No heat exchanger.
snapmorgan is offline
Old 09-15-2023 | 12:45 PM
Have you checked for "bravoitis" ?
87MirageIntruder is offline
Old 09-15-2023 | 01:05 PM
Brand new gimble assembly,
Nfast is offline
F-2 Speedy's Avatar
F-2 Speedy is offline
Old 09-15-2023 | 01:07 PM
I didn't back flush to oil cooler though, When I take the hose going to the thermostat off, has really great flow, why i didn't think I needed to do it,
Nfast is offline
Old 09-18-2023 | 12:08 AM
Reach inside the water intake side of the oil cooler and check for any debris
Griff is offline
Old 09-27-2023 | 07:28 PM
What gaskets are on the end caps of that oil cooler,?
Nfast is offline
