Lifter making noise
#91
I always run the stock GM dogbone lifters when I can. I have ran them to .635 lift and about 450# spring pressure without a failure. If you don't have a gen 6 block or need more lift or spring you are SOL.
#92
I think the Comp lifter is very susceptible to dirt in the oil gallery. I’ve been doing a lot of reading on this and have come across others that have found grit to be the issue. Is this coming from assembly issues of the lifter itself, or insufficient cleaning practices? Maybe this is why other makes are failing.
The blown 454 that I had ran into a similar issue with a Comp 854 lifter. This was years ago but the failure was the same. These lifters had been used in another engine for a good many hours without any issues. I had two fail within an hour of being run on the dyno. Looking back on in, the only thing I can think of is that there was contamination - from my recently machined 454 block.
Since you probably won’t get anywhere with Comp, I think it would be a worthwhile to open up the bad one to see what caused the plunger to stick.
#93
You could always contact Billy and see if theres anything he can do for you ...
I bet if you send him the part back he`ll send you a new set ..
.From: Billy Godbold [[email][email protected]]
Sent: Tuesday, November 09, 2021 7:58 AM
To: Daniel Baloun @ AccuMax Inc.
Cc: Walter Britton; Chris Potter
Subject: RE: new lifters
Hi Daniel,
We have a better lower design on the new lifter (stronger ears with a longer skirt), but I know Chris would love to see yours. Can you email Walley and see if we can get those back for inspection. You would not believe how valuable damaged parts are for us as we work to continually improve our designs and manufacturing methods.
Thank you,
Billy
Billy Godbold
COMP Cams Valvetrain Engineering Manager
Edelbrock Group
Hi Dan,
The COMP Cams, 3406 Address below is best. Sending them “ATTN: Walter Britton” would keep me from losing them…
Billy Godbold
3406 Democrat Road
Memphis, TN 38118
Direct: 901-375-3412
[email protected]
Hi Daniel,
Thank you,
Billy
Billy Godbold
Edelbrock Group
Hi Dan,
Billy Godbold
3406 Democrat Road
Memphis, TN 38118
[email protected]
#94
Getting a good clean on the oil galleries is hard to do if not setup for it, or don't have good assembly practice...or just have Mr. Murphy come for a visit.
Seems that opening up the Comp lifters and inspect/de-burr and tolerance check would go a long way to avoid the stuck plunger...should someone 'have to run the Comps'.
It certainly makes a good case for solid lifters, if you have the easy space to both pull the rocker covers and bar over the engine for the lash adj.
Also making the case for mild cams and blowers...
#95
LOL. Having a home-made set of valve covers with the holes drilled above the rocker adj's helps considerably. Otherwise, gotta keep the idle rpms as low as possible. Having a cold one handy is always a good idea in case there's a flare up.
#96
A couple of cold ones… because you can never be too careful!
#97
#99
GOod to hear! Can you describe what the noise sounded like? Mine isnt' a perfect higher pitched "tick" noise. It's a little bit odd. Also - I can't differentiate which side it's coming from so this makes me think it's lower in the valvetrain. I had 4 guys here one day listening to this thing trying to determine what it was.
#100
