Lifter making noise
Thanks again.
A better shot of #1???
Your plugs look terrible, your tune is definately too rich SOMEWHERE.
how far are your 02 sensors from water? ICL/LSA/ .050 duration of cam?
your rocker arms are poorly lined up, you clearly have adjustable guide plates, use them to align your rockers properly and relash the valves.
Comp cams hydraulic roller lifters are cheaply made, pretty sure there imported . I would cycle them out at some point before 100 hours for good Johnsons before they fail and destroy your engine as they are worse then Morels which have a terrible track history these days. And thats assuming you just have one out of adjustment at this point and not one failing already. Good luck with it
Hydraulic roller lifters are a sore subject for a lot of people these days. It probably has one collapsed although you need to start with getting the guide plates adjusted correctly and setting the valve lash again. I wouldn't even want to suggest what brand to use as all of them seem to have issues in the last 5 years or so. If it were mine, I would probably put in some solid lifters and tight lash them.
Not much point to those adjustable guide plates.
These were CompCams best lifter with billet blah blah blah..
The needle bearing and schrapnel thru the entire engine was cool.
