formula 292sr1 454 exhaust upgrade info needed >
Old 09-16-2023 | 09:56 AM
Default formula 292sr1 454 exhaust upgrade info needed
Hi Im thinking of upgrading my stock 454 magnum manifolds and risers to high performance manifolds and risers. Any suggestions on an upgrade, I don't know much of a difference between the companies producing them, other than they are very expensive! Eddie marine, or Harden, or other companies. If anyone can suggest a nice setup that will bolt right in that would be great. Boat is bone stock 1988 Formula 292 sr-1
Thakyou
tpivega is offline
Old 09-16-2023 | 10:37 AM
TomZ's Avatar
Stainless Marine. They’ll support any upgrades that you might decide to make in the future, and they’ll last a long long time.
TomZ is offline
Old 09-16-2023 | 10:42 AM
TomZ's Avatar
Hardin also has copies of the Merc/Gil exhaust that were options on hi-perf engines. Those could be options, too.
I’d still lean toward Stainless Marine. They may also fit a little better than the Hardin manifolds (a little extra room between the engines).
TomZ is offline
Old 09-16-2023 | 11:11 AM
I’d have to agree with Tom however you’ll see Zero gains unless you plan on cam intake and heads upgrade down the road. If so then perfect place to start!
getrdunn is offline
Old 09-16-2023 | 12:33 PM
...BUT be careful with aggressive cams (lobe separation angle, etc...). Dry pipes offer more options in performance tuning.
F14A water jet is offline
Old 09-17-2023 | 12:02 AM
Ya sounds good, as I need that little extra room to get my arm inside between the engines when acessing the petcocks and hose removal for winterizing.
tpivega is offline
