Help diagnosing mercruiser 502 mpi with mefi 1 and VST EXTREMELY LONG
#32
It may very well be already stuck in service mode, the one I dynoed that had a bad connection that was green in the loose butt connector I found in harness made no diffference whether i put a jumper wire in fwiw until I fixed it. It would work normal randomnly if i wiggled harness near distributor until I found that. it was down 20% in power and afrs plunged to rich side when the est wire didnt tell it to go on normal timing table at 300 rpms like it was supposed to if i pulled it on dyno.
#33
that would make sense. Also, if I’m putting it in service mode with the rinda scanner, should it ever come “out” of service mode by itself? There was a few times I was trying to check, I’d hear a ton change, look back at the scanner and it read “normal mode.” I’m not sure if there’s a time limit where it goes back on its own or something’s bleeding through causing it
And once your scanner gets unplugged, or scrolled back, it would no longer be in service mode from anything the scanner did
#34
I had a spare few minutes today and I ran down to the boat with the meter.
first, ecm is 16220371
I checked voltage on the bypass wire at idle, 4.0v. Rev’d to 1700 and it went down to 3.9.
key on, engine off, there was 400ohm resistance to the ecm ground(black/red) and the IC wire (white)
not sure if it not actually receiving 5v is the issue
#36
Key on, engine running, the % and voltage increases as soon as the the throttle lever is moved like its supposed to and goes all the way to 100% and 4.55 volts
What would cause this? There's certainly resistance somewhere but any know where to start looking?
One other thing i noticed is on the Rinda scanner, it reads 13.8-14.2V and kind of moves around a lot between there while at steady throttle. On the dash, it reads as low as 13.1 and stays there. I need to verify the difference within the gauge today to make sure its working appropriately.
I started pulling inline fuses to all the accessories and I noticed that one fuse that powers the trim motor AND both tab motors.Is that normal?
Starboard tab moves much slower than the port.
When using starboard tab, voltage drops to 12.5 and recovers back to 14 quickly while still using it.
Port tab dumps to 11's and does not recover until you take your finger off the button.
It may be unrelated but Ill also look into that.
#37
I don't see where you had the MEFI 1 inspected for internal damage. They are known to puke themselves causing all kinds of electrical gremlins.
As far as your trim tabs and drive trim mine are wired together as well. My tabs also drew down battery voltage the same (even at high rpm) and after ruling out a bad pump I hardwired the helm switch power in to the battery (w/fuse) and the issue went away. I've had to do this with other accessories as well and chalk it up to the 27 year old harness being corroded as forum members haven't suggest any other reasoning.
#38
I just switched everything (intake manifold, carb, lines, etc) from my old boat to this one and it’s doing the exact same thing…. So it can’t be the ecu. Only thing left is a few battery/charging wires, ignition switch?
#39
If you're running the Delco distributor, there should be nothing connected to the 4-pin connector. The distributor only needs power and the output to the coil (negative side).
Could be the video, but the engine doesn't sound right to me. Have you done compression and leakdown tests that were asked about earlier in the thread?
#40
So since my last post, I did the carb, fuel lines, confirmed pressures, I put a new engine/charging harness, pulled the distributor and swapped it with my other boat and put a TB V module in…. With no f******* change. Today I mounted a go pro under the swim platform because it really did feel like it was hill/drive related..and correct me if I’m wrong but the water being thrown in the beginning of the video is completely not what is supposed to happen?
I will get the actual video uploaded soon. I’m just still out so this is all I have for now
