# end to end turns >
# end to end turns
# end to end turns
Old 10-14-2023 | 03:18 PM
scippy's Avatar
Default # end to end turns
Would 4-1/2 turns (lock to lock) be right for hydl. steering?
scippy is offline
Old 10-14-2023 | 03:43 PM
Mighth work, but i prefer less revolutions. Mine is 3.5 revs. If your boat is handfull to drive at higher speeds, the 4.5 may be too much.
JaniH is offline
Old 10-14-2023 | 04:11 PM
scippy's Avatar
air in system after replacing broken hydl. line from pump to helm ....added hydl. oil in pump as my daughter turned steering wheel
countless turns from left to right before any locking.......best lock to lock was 4-1/2 turns.....Imco dual drive hydl. steer...can't remember
what is was before.
scippy is offline
Old 10-14-2023 | 04:17 PM
F-2 Speedy's Avatar
F-2 Speedy is offline
Old 10-14-2023 | 08:57 PM
It depends on which rams and what size helm pump
Page 72 imco-catalog-2022-v10.pdf (imcosteering.com)
Griff is offline
Old 10-15-2023 | 03:21 PM
Mine is 8 turns so you`re fine.
ICDEDPPL is offline
Old 10-15-2023 | 07:32 PM
ben
mine is about 4 turns lock to lock so sounds about right. ram size probably makes a difference.
ben is offline
Old 10-16-2023 | 11:24 AM
TomZ's Avatar
Latham rams and a Eaton helm on mine - about 4 turns lock to lock. Maybe 4.25. It gives a lot of fine control. I think you're fine.
TomZ is offline
Old 10-16-2023 | 12:19 PM
scippy's Avatar
I have a typical CharLynn helm with 2 Imco rams, hoses, tie bars etc; etc; .. turning 2 ssm 3's ...not sure about the helm displacement, but figure I'm good by responses.
scippy is offline
scippy's Avatar
not excessive ....8 turns?
scippy is offline
