Losing Spark >
Losing Spark
Losing Spark
Old 11-05-2023 | 12:48 PM
Craney's Avatar
Default Losing Spark
I’m losing spark on my DUI distributor, I charged the Module to Hei flame throwe,I got spark then lost it again.I checked all the connections and they seamed to all good.I just don’t know why I’m losing spark I have a spark plug tester.
Craney is offline
Old 11-07-2023 | 05:19 PM
mrv8outboard's Avatar
coolrunning racing
Is this the GM coil on cap type? If so change the rotor.
mrv8outboard is offline
Old 11-07-2023 | 05:43 PM
Craney's Avatar
They are very similar to hei distributor,coil in the cap.
Craney is offline
Old 11-07-2023 | 07:16 PM
SB
Describe the lose spark in more detail please
SB is offline
Old 11-07-2023 | 07:26 PM
Craney's Avatar
I had spark on the tester, I took it off and went to start it and didn’t start I put the tester back on and no spark.
Craney is offline
Old 11-07-2023 | 07:43 PM
When I lose something I always start looking at the last place I remember having it but usually I have to get my wife to find it.
ICDEDPPL is offline
Old 11-07-2023 | 08:23 PM
Craney's Avatar
I don’t have one to tell me where I lost it.
Craney is offline
Old 11-26-2023 | 12:59 PM
Craney's Avatar
I think I found my problem, took the coil off starboard motor ( this motor starts right up) put the starboard coil on port motor, motor starts up. I was looking at the coil and noticed the little ground wire in the coil had the black shrink wrap covering almost the bottom where it grounds in the cap.I cut the shrink wrap off the bottom of the ground wire put coil in the starboard motor, motor started right up.
Craney is offline
