Port engine lean. Why? >
Old 02-06-2024 | 09:16 AM
TomZ's Avatar
Yep, I have some old iphones as well as go-pros that I can put in there to see what's going on. I didn't the last time it was out, but I'm thinking of going out without the engine hatch on so we can see what's up a little more easily.
Any thoughts about the vacuum readings? They look okay to me - nothing too far off from one another.
TomZ is offline
Old 02-07-2024 | 07:16 PM
Rookie's Avatar
Tom,
I found your problem. You can thank me later...
Originally Posted by TomZ
everything was great until I screwed around with them
Rookie is offline
Old 02-07-2024 | 10:54 PM
TomZ's Avatar
Hahaha… Thanks!
TomZ is offline
Old 02-08-2024 | 02:20 AM
Not really. So many little things that can make manifold vacuum slightly different.
Did have a random thought abt the power valve... AFAIK, most carbs have a check-valve to protect the power valve diaphragm form excessive pos press spike during a back-fire event. My old carbs don't have the check valve and if I get backfire during start-up, it blows at least one of the power valves out. So if yours have a check valve, make sure it's not stuck closed blocking the vac signal.
zz28zz is offline
Old 02-08-2024 | 11:04 AM
TomZ's Avatar
Thought about that one… the trouble is that if vacuum is closed off, the pv will hang open and allow more fuel.
TomZ is offline
Old 02-08-2024 | 10:36 PM
Doh!! You are correct. It was past my bedtime last night.
zz28zz is offline
Old 02-09-2024 | 07:05 AM
TomZ's Avatar
Haha! I had a similar response in the original thread I posted about the carb being off. Glad I’m not the only one!
TomZ is offline
Old 02-10-2024 | 04:16 PM
TomZ's Avatar
Alright. Both carbs are back on the bench. I took everything apart and have somewhat of any idea of why these things have been problematic.
The vacuum source for the PV’s on both carburetors were never drilled. The PV’s were never working to begin with. I’m not sure how I missed it - I guess I just assumed they were drilled in a different manner (connected to another vacuum channel perhaps). Nope - I fished through every hole to make sure there was no trash anywhere.
What a waste of time.
For now I’ll baseline the carbs back to 86 and 93 and see what it does (it has 84 and 90 jets now). PVCR is opened up to .063 from .059. We’ll see where we end up. The original combination seemed close with the 86s and 93s at wot.
TomZ is offline
Old 02-10-2024 | 05:25 PM
Is this the vac passage in the main body or the fuel passage within the metering block from PV to booster circuit that wasn't drilled?
If it's the vac passage in main body, wouldn't the PV be ON all the time??
Here's a pretty good video on Holley power valves. It's geared more towards cars but he explains the operation pretty well.
zz28zz is offline
Old 02-10-2024 | 06:55 PM
TomZ's Avatar
It was the vacuum orifice in the baseplate. There was nothing making it to the PV.
I dropped a lot of main jet and that messed the whole thing up.
TomZ is offline
