O ring size for block fitting for mercruiser fuel rail >
Old 12-17-2023 | 06:06 PM
Default O ring size for block fitting for mercruiser fuel rail
I have a gen 6 454 mag mpi gen 3. There is a brass block with 2 o rings that go into the port side in the middle of the fuel rail. The schematic only shows 1 in the drawing and says 1 required. Any idea if they are the sane size? I'm assuming yes but my eyes start playing tricks on me. This is the part number listed 25-805970
rusty12 is offline
Old 12-18-2023 | 12:32 AM
Guessing you have a VST system?? By the looks of the diagram, you would need one O ring for each hose that goes into the end of fuel rail
VAPOR SEPARATOR TANK AND FUEL RAIL (mercruiserparts.com)
Griff is offline
Old 12-18-2023 | 04:59 AM
No vst. Cool fuel. Schrader valve at front end on fuel rail. Fitting in the back is plugged
rusty12 is offline
