Water in engine. Rebuilt 700sci >
Old 02-23-2024 | 12:10 PM
Originally Posted by underpsi68
That is a massive leak to hydro lock 2 cylinders in 2 minutes of idle time.
I was thinking the same thing, a leak that large would point more towards water from the manifolds?
Ryanw10 is online now
Old 02-23-2024 | 12:23 PM
These are closed cooled engines, and it was anti-freeze in the cylinders. It can't be the manifolds....
302Sport is offline
Old 02-23-2024 | 12:37 PM
Maybe there is 2 separate issues going on here? Like there was water and antifreeze in the cylinder, so head gasket and manifold issue? I have seen engines run longer than 2 minutes on a blown head gasket.
Old 02-23-2024 | 02:05 PM
manifolds are Hardin and brand new.
I doubt they would be leaking that much straight out the box
the whole point of getting them was to avoid the leaking of cmi’s
intimid8 is offline
Old 02-23-2024 | 02:16 PM
F-2 Speedy's Avatar
Do you know what head gaskets were used ?
F-2 Speedy is offline
Old 02-24-2024 | 12:50 PM
Head gasket or intake manifold gasket is the most likely cause
Griff is offline
Old 02-25-2024 | 11:26 AM
F-2 Speedy's Avatar
any update
