502 mag fuel system >
502 mag fuel system
502 mag fuel system
Old 03-22-2024 | 01:30 PM
TomZ's Avatar
The tank will be a bigger heat sink but you can also do this by running the return back to the filter/water separator. Merc did the same with their Cool Fuel set-up (Cool Fuel should not be confused with VST - VST is problematic at best).
TomZ is offline
Old 03-22-2024 | 06:00 PM
SB
Originally Posted by AllDodge
Run the return to tank side back to fuel fill hose. They make Tee fittings which will work
Here’s 1. I think they make/sell 2 different ones.
https://www.cpperformance.com/p-1368...k-adapter.aspx
SB is offline
Old 03-23-2024 | 08:10 AM
Thank you all for your input, awesome team of experts! I will send a line back to the tank with the proposed fitting.
sandslot is offline
