525sc no  water pressure >
Old 03-27-2024, 06:32 AM
Originally Posted by Griff
Do you mean that you have ZERO psi of water pressure???
That is nearly impossible if you have some flow. My 525SC had around 1-3psi at idle and 20psi at WOT
First thing to do it verify that the gauge is working and the hose to it is not clogged. Where is the hose connected?? If its at a block drain, its probably clogged in the first few inches or it has a kink somewhere
Yeah, I'll double check.I'll probably just get a new Gage and double check, How would I go about clearing out that line if it is blocked,
Nfast is offline
Old 03-27-2024, 09:20 AM
a thin piece of wire
sutphen 30 is offline
Nfast (03-27-2024)
Old 03-27-2024, 11:24 AM
Zip tie in a drill works wonders as well.
Precision is offline
Old 03-27-2024, 12:55 PM
What else could cause my high temp alarm to go off, When the gauge reads normal
Nfast is offline
Old 03-27-2024, 01:53 PM
Perhaps the temp switch is faulty or the gauge is reading incorrect? Have you had a chance to verify the actual engine temp with an IR temp gun?
Wrench is offline
Old 03-27-2024, 02:15 PM
not yet. Headers were really cold to the touch as well, if that means anything. Almost like it feels all the water is going to the headers and not through the block
Nfast is offline
Old 03-27-2024, 03:23 PM
Oil pressure switch, water temp switch and drive reservoir are all spliced together on the 525SC.
Id bet you have no water issues, but a switch issue. If I recall correctly that is a 190* switch, next time shoot the thermostat housing with a IR temp gun and verify your 140* water temp. If your gauge is accurate, then replace the over temp warning switch.
The following 2 users liked this post by Precision:
Griff (03-27-2024), Nfast (03-28-2024)
Old 03-27-2024, 03:54 PM
again,the thermostat housing needs to be looked at.
easy way too,take it apart and switch positions of the brass collar and thermostat.
Griff (03-27-2024)
Old 03-28-2024, 11:58 AM
So right now the brass collar is down on the bottom, my thermostat sits on top, I'll swap em as well.
Nfast is offline
Old 03-28-2024, 02:15 PM
yup,swap the position.thermostat thats your problem.
The following 2 users liked this post by sutphen 30:
Griff (03-29-2024), Nfast (03-30-2024)
