-   -   Lets talk oil filters (https://www.offshoreonly.com/forums/general-q/382116-lets-talk-oil-filters.html)
the deep 04-15-2024 01:09 PM
https://cimg4.ibsrv.net/gimg/www.off...c2b872d87f.jpg
Brad Christy 04-15-2024 01:11 PM
Guys,
So, I read that the new K&N HP3003 is the old 3002. I've also read that the only difference is that the old 3003 has a built-in bypass valve, and the old 3002 did not. Does this mean that the 3003 I've currently got, after ordering a 3002 (Amazon), does NOT have the bypass valve? How do I know if I have the if I have the NEW 3003 or the OLD 3003? And, with the stock Merc 496 configuration (oil temp sender mods aside), do I NEED a bypass valve, in addition to one that may or may not already be there? Is there one in the stock configuration?
Thanks. Brad.
87MirageIntruder 04-15-2024 03:54 PM
The factory 496 gen 7s have a 30psi bypass valve located in the block. You don't need a bypass valve in the filter but either way would run fine.
Brad Christy 04-15-2024 04:02 PM
:ernaehrung004:
articfriends 04-15-2024 05:31 PM
60 microns equals: 0.0023",, since a regular 51060 or 61 flows MORE THEN A TYPICAL BBC PUMPS, theres NO absolutely reason to run the R series of filter on a recreational boat, heavier can, great, since no ones exploding "standard " wix filter cans thats ZERO benefit too.Unless your putting your throttle on dashboard with your oil at 70 degrees, which no one should be doing, the regular 60 and 61 filters Six to EIGHT TIMES better fwiw
ICDEDPPL 04-15-2024 07:18 PM
If I have a choice to run a better fiter with a better micron rating why would I chose a Racing filter designed for flow on race cars? .. even if an engine went 100 passes without changing oil or filter (nobody thats smart would do that) thats 10 hrs. I certainly don`t change my oil every 10 hrs.
I`m running the filter with more filtration, to me that`s a no brainer.
I like my filters to filter .. never had a flow issue due to a filter being too good.
the deep 04-15-2024 11:10 PM
They say pictures speak a thousand words. As a side note, this HP 500 had 17 hours of offshore factory race time when I bought it. Never used a drop of oil which is crazy for a BB. You guys telling me I just got lucky my chit didn't blow up? I'm showing you empirical evidence. We don't run in a dirt track environment. 15W50 Mobil 1 changed every 50 hours. :party-smiley-004:
https://cimg1.ibsrv.net/gimg/www.off...c1bfc226aa.jpg
https://cimg2.ibsrv.net/gimg/www.off...5a5f5daf92.jpg
https://cimg3.ibsrv.net/gimg/www.off...25c130f6ae.jpg
Joeyboost 04-16-2024 07:43 AM
So that brings up another question, oil weight to go along with a good filter, I just had the 502 Mag in my boat rebuilt its now a 509 with a hotter cam and 9.3:1 compression. Its a lake boat so high RPM runs for long periods of time do NOT happen, I ran Rotella 10w40 in it last season as a break in but is that to light of an oil? Do I need to run 15/50?
Wally 04-16-2024 07:56 AM
I always ran a straight 50W (Valvoline VR1) you dont really need the first number as its for cold weather (winter) running equivalent....
87MirageIntruder 04-16-2024 09:23 AM
I'm a big believer in plenty of flow on a high performance marine engine don't get me wrong. that's why I run -12 lines, full flow bends, etc. I run the 2 quart super long oil filters so I can get way more flow than I'd need, while also getting filtration in the 20-30 micron range. Oil analysis particle count results show they are filtering out the particles in the size range they should. It's about surface area of the media, so get a filter with lots of pleats and as long as you can fit. There was a study done years ago on engine wear and it was found on a typical engine with average clearances, particles less than 20 microns didn't cause significant wear, they just passed through.
Brad Christy 04-16-2024 10:17 AM
Guys,
Maybe it's my lacking Google skills....
Can anyone tell me the filtration size for the K&N3002(3)? I can't find anything about it anywhere. All the links that pop up only parrot what K&N has on their website. I don't really need to know the OD and OAL......:rolleyes:
Thanks. Brad.
Brad Christy 04-16-2024 10:22 AM
Smitty,
Coming from a machining vantage point, that sounds incredibly large. I have course lapping compound with smaller grit particle size than that. I can't imagine anything that large flowing toward a main journal. Ick....
Thanks. Brad.
SB 04-16-2024 11:31 AM
Originally Posted by Wally (Post 4895380)
SB, where was that filter made? It seems like the ones i have that are US made all have the black seals in them...yours has red....my buddy that had the Napa Gold from China had the red seal in it as well....
Made in the USA. :(
https://cimg0.ibsrv.net/gimg/www.off...9f5c0c91c.jpeg
https://cimg5.ibsrv.net/gimg/www.off...e04a01c9b.jpeg
https://cimg6.ibsrv.net/gimg/www.off...8d80c9b88.jpeg
Joeyboost 04-16-2024 11:36 AM
https://www.amsoil.com/p/amsoil-z-ro...motor-oil-zrd/
Anyone run amsoil, debating running Z-rod 10w40 this season for the high Zinc in it.
Wally 04-16-2024 12:03 PM
Originally Posted by sb (Post 4895750)
made in the usa. :(
ouch! :(
Brad Christy 04-16-2024 12:17 PM
Joey,
I'm getting ready to switch to their 20w50. Got the oil and K&N filter; just waiting for the oil temp sender from Gaffrig to arrive so I can do the modifications to the filter mount during the oil change. I opted out of the Z-Rod formula. The standard 20w50 says "High Zinc" on the jugs. Not sure how much is in either.
The reports I read on scorch tests and such, and insight from here on OSO, leads me to believe AmsOil is about as good as it gets.
Thanks. Brad.
Diamond Dave 04-16-2024 12:39 PM
I ran Amsoil Dominator in my last boat for a minute. If you believe the interwebs, Bob Teague likes it.
the deep 04-16-2024 01:29 PM
I personally see no problem running a 15-50 synthetic, 50 indicating the strength of the film. Poor marine engines are always in heavy load mode and up in rpm's. Size of the boat and weight determines the demands put on your engine/engines and may be just one of the reasons I see the results I do with my filter/oil combo which can not be denied. 25' cat and very little drag. One size does not fit all in our world.
Tartilla 04-16-2024 11:50 PM
0.0025" main bearing clearance is 63 microns.
There's studies that say small 20 micron cause the most wear and many that don't.
The crank won't stay perfectly centered within the bearing, and when loaded, likely bends taking up much of the clearance. 20 micron contaminants would start contacting at 0.0008".
Soot will wear down parts by abrasion, but that is more a diesel issue.
There are other methods to polish the oil in the pan or dry sump tank. Use an additional small flow higher pressure electric pump that flows oil just through a finer filter and back into the pan.
Where is the contamination coming from?
How clean is the air going into the engine?
Joeyboost 04-17-2024 06:51 AM
I was running mercruiser 15w50 in my stock 502 Mag but I want to be sure I run what's best for the new engine. It has about 8hrs on the engine so I would assume switching to a full synthetic is fine now.
Joeyboost 04-17-2024 07:05 AM
Originally Posted by Brad Christy (Post 4895756)
Joey,
Thanks. Brad.
Which Amsoil ae you going to run if not Z-Rod? Dominator?
https://www.amsoil.com/c/gasoline-mo...ce&pageSize=20
Looks like Dominator isnt offered in 20w50 only Z-Rod
Brad Christy 04-17-2024 07:43 AM
Joey,
THIS
Thanks. Brad.
Joeyboost 04-17-2024 08:21 AM
Ok cool I just ordered 9qts for $110.00
the deep 04-17-2024 08:57 AM
This right here. Low tension ported metric rings and plateau honing = redused friction(particles),less heat and a proven gain in power output.
How clean is the air going into the engine?[/QUOTE]
sutphen 30 04-17-2024 06:29 PM
amsoil saleman took that pic.wink wink :)
SB 04-17-2024 06:44 PM
I recently got 10quarts of Valvoline vr1 20w-50 for $50 total and 10 quarts of mobil 1 15w-50 for $50 total also.
Both included free shipping.
Tartilla 04-17-2024 08:19 PM
Great Price on the VR1.
I have the System 1 stainless mesh re-usable filter. I have to confirm the micron rating. There's different sizes available.
Should be interesting to see how they work out. Cleaning them pay be a PITA.
Big_Baller 05-10-2024 03:52 AM
I run a clearview 60 micron same as wixR which lets me check filter when I want to see if it has anything concerning in it, with oil changes every 25h or so. All -12AN lines and an accusump to on start up and god forbid an dips in oil pressure underway.
https://cimg4.ibsrv.net/gimg/www.off...c465f32a2.jpeg
https://cimg5.ibsrv.net/gimg/www.off...bd2d6ed2e.jpeg
spazz 05-13-2024 07:56 PM
I use this on my 502.
https://www.quicksilver-products.com...ce-v-8-engines
