MSD 6M-2L BOX need ground ?
Let’s talk about the MSD 6M-2L box
Last night a want to start my engine on the stand .
i dont mounted my box on the braket so i put a old shirt on the bloc for not scratch the paint an drop the MSD box on it . Plug the black wire on the ground and the red on positive and 12V on the ignition .. the engine wont start … no fire . After a lot of test i took a wire directly on the corner of the box and go to the negative terminal on the batterie, engine start and run find . Y remove the wire and the engine shut off …
so if it’s normal that the box need to be mounted on as ground surface ? Or me box have a problem ?
Yess the black wire on the box is ground directly on the battery terminal . In the boat the box is mounted on the metal braket on the engine and run fine . But if the box does not mounted on the braket will not fire . I need to make the box housing ground to have fire .
when I run engines with MSD boxes on the test stand the box is usually just laying on the ground. if you are having to ground the case then I would say there is a broken ground circuit inside the box.
thanks you .
