Replace this trim switch in handle >
Old 06-13-2024 | 07:23 PM
Default Replace this trim switch in handle
How much pain am I looking at having to change this switch .
open87 is offline
Old 06-14-2024 | 06:36 AM
Not that hard. Need to find the control for list of parts
https://www.mercruiserparts.com/remo...and-components
Move throttle full forward. In this position the neutral button can be popped out. Once out the throttle goes back to neutral and the retaining nut can be removed
AllDodge is offline
Old 06-14-2024 | 06:59 AM
Oh and it may not be that switch, can also be the connector by the pump which connects switch to pump assembly
AllDodge is offline
Old 06-14-2024 | 07:21 AM
I’m pretty sure it’s the switch , won’t go down , tried switching at relays and still nothing , if I put blue plug on either relay I’m getting clicking
Try Green plug on either relay and nothing .
open87 is offline
Old 06-14-2024 | 07:23 AM
I emailed Marc and asked him to check out this thread I’m sure him just looking at it he would know which switch but did they get flooded with all that rain ??
open87 is offline
Old 06-14-2024 | 07:48 AM
Mbam's Avatar
Offshoreonly Advertiser
Nope, not flooded out by us but it certainly is a bit soggy around here.
Just poke around the link AllDodge posted until you find the control that looks like that. To be honest I can't remember the last time I worked on one of those.
Mbam is offline
Old 06-14-2024 | 08:02 AM
Ok
will do
93 Cobalt so yeah , pretty old .
Thanks men .
open87 is offline
Old 06-22-2024 | 06:56 AM
Local boat dealer had the switch for handle (shocked really) just has different plug so will be splicing in , got a a pair of new OEM Volvo Penta relays from GLS .
Everything now operates.
So a simple seal replacement from 5 Star Marine on trim rams, new API pump since original was sounding weak , then the electrical bug . Going today to complete re assembly . I am thankful though that the electrical bug happened at storage building and not on the water , etc....
Thanks again men.
open87 is offline
