500 efi won’t start >
500 efi won?t start
500 efi won’t start
Old 06-26-2024 | 10:14 AM
F-2 Speedy's Avatar
So one runs and the other doesn't ? cranks but no spark ?
F-2 Speedy is offline
Old 06-26-2024 | 10:38 AM
Yes, port runs, no issues, star is not pulling fuel, nor sparking.
BYFS is offline
Old 06-26-2024 | 10:57 AM
Originally Posted by BYFS
No antisyphon in this system, fuel line is fine, pick up is fine, yes there is fuel in the tank, and it’s hard to believe not one gremlin hit this off season but two? Fuel and spark! Inlet in remote tank will be performed today (results tbd)
Right now forget about no spark, find out why no fuel
Use a gas can and length of fuel line. Disconnect fuel from tank at filter, Connect gas can line to filter
Prefill filter
Edit, remove filter and dump contents into clear container
AllDodge is offline
Old 06-27-2024 | 10:40 PM
You confirm your in neutral…you check neutral switch on shifter
1MOSES1 is offline
Old 06-28-2024 | 12:51 PM
Fuel delivery issue solved, ZERO spark! Inspected distributor, looks fine, rotor spinning, swapped the ignition module, which was not the problem!
BYFS is offline
Old 06-28-2024 | 01:21 PM
My next guess would normally be the distributor pick up coil, but hard to believe it would suddenly go bad while layed up.
So' I'm more leaning toward a wiring issue where some corrosion developed
Here is a TB V troubleshooting flowchart
Griff is offline
Old 06-28-2024 | 01:24 PM
What was the fuel issue?
Trash is offline
Old 06-29-2024 | 10:01 AM
Primed it 3 times, finally took.
BYFS is offline
Old 06-29-2024 | 03:18 PM
I had a terminal end corrode away inside the connector of wires coming from pick/up to ignition module. Difficult to see but no spark.
liberator221 is offline
