Starter question again
Thanks to whoever moved this thread. I am not able to because of my basic membership.
BillK, I checked over all the grounds when I reinstalled the engines last year. I didn't go over the positive side though. I have decent access to area's now after removing the exhaust so I will go over all of the connections.
I did not at the time of engine reinstallation but now am using a dielectric grease on many connections. Do you guys recommend doing that for all electrical connections?
They might look perfect and clean but they actually are not.
Also make sure ign timing isn't too far advanced at idle. Once had MSD distributor advance weights/springs rust (on both engs) and ign was stuck at full advance. Starter was fighting against cyls firing too early. Actually bent the starter bolts on one eng.
In addition to checking the batt cables and ground cables, check the voltage coming from ign switchs that engage the starters. I've seen where the ign switch was old and passed enough current to make the solenoid click sound but not enough to fully engage the solenoid. This lead to the contacts in the solenoid burning up prematurely.
It turns out that I didn't adjust the valves correctly after replacing the one set of lifters and then I went through both engines to better align the rockers. Anyway, I hooked up a remote starter switch directly to the starter solenoid and the starters worked fine every time I hit the button. Thanks for the heads up.
I once had the square plug under the dash full of corrosion. (yellow/red wire) It had enough voltage to click the solenoid but not enough to maintain continuity and actually engage starter. Took a while to find that one.
On the bright side, I now have more ground connections than needed so that shouldn't be a problem for a while. I have replaced brand new starters with brand new(er) starters. I have new ignition switches (they needed replacing anyway) and now have a better understanding on how some things work.
I knew the problem was going to be me, I just had to find out where I went wrong. My apologies to you guys that tried to help me. It's hard to help someone when you don't' have all of the info. I changed out the engine wiring harness and failed to mention that.
Thanks to everyone for your help.
