carbed 502 running too cold >
Old 08-06-2024 | 08:00 AM
Originally Posted by sutphen 30
does the thermostat have a bypass hole in it?if not,add a couple of 3/16" holes
The one I pulled out had two holes, the new one had none...I get it, with the two holes the manifolds will get some water...but won't letting it bypass keep it running cooler? I'm trying to get it to heat up...
Zekester is offline
Old 08-06-2024 | 08:05 AM
Zekester is offline
Old 08-06-2024 | 10:18 AM
this motor ever apart?
sutphen 30 is offline
Old 08-06-2024 | 10:41 AM
yes, it's just been rebuilt, only has 8 hours on it...it runs at 120F on the hose, but cools right down in the water...
I have other issues with it, if you look at some of my other posts...I'm just trying to get through things one at a time...
Zekester is offline
Old 08-06-2024 | 09:39 PM
My 1993 454 mag ran a 6 hose T stat housing original from Merc. Like I said earlier, either Tstat housing should work fine if plumbed and assembled correctly
Mine was the same as what you have. Merc diagram THERMOSTAT HOUSING(STANDARD COOLING) S/N: 0F3519999 & BELOW (mercruiserparts.com)
Griff is offline
Old 08-06-2024 | 09:46 PM
I've lined up everything as per the parts drawings I can find. I did check the gauge but not the sender, I have a new one i'll change it next, I'm going to change out the tstat and put the one with the 2 holes in it back in, just to get some flow to the exhaust manifolds....
Zekester is offline
