5.0 mpi to 5.7 mpi >
5.0 mpi to 5.7 mpi
5.0 mpi to 5.7 mpi
Old 08-15-2024 | 03:11 AM
Default 5.0 mpi to 5.7 mpi
Hello from Austria,
I would like to convert my 5.0 MPI to 5.7 MPI.
Can someone edit the engine control unit for me?
I also have the Axius joystick system.
Boat was built in 2009.
Thank you in advance.
Bavaria1994 is offline
Old 08-15-2024 | 09:26 AM
You cannot convert a 5.0 to a 5.7 but you can replace the 5.0 with a 5.7 or even 6.2
Reprogramming the PCM is not that easy and may not be able to be accomplished, but replacing with a factory one program for a 5.7/6.2 is
What is your motor serial number?
AllDodge is offline
Old 08-15-2024 | 12:17 PM
hello, yes of course I mean swapping to a 5.7.
Serial number: 0w962289
The control unit is available new from Mercruiser for 5.7 with closed cooling and Axius.
However, it costs around 3000 euros per engine...
thanky you!!!
Old 08-15-2024 | 02:41 PM
The SN is coming up a Bravo drive
Yes it will be pricey, new ECM comes in at $2700 USD here
Not even able to buy a "new" 5.7, it's either the 4.5 or 6.2
If you get a new long block and ECM you should be able to use everything else off your motor
AllDodge is offline
Old 08-15-2024 | 03:36 PM
TomZ's Avatar
I would look at part numbers to see if there are any real differences. The tune for a 5.0 and 5.7 can't be that much different.
Last edited by TomZ; 08-15-2024 at 03:41 PM. Reason: Lots of different part numbers dependent upon model.
TomZ is offline
Old 08-15-2024 | 03:39 PM
TomZ's Avatar
Do you have the engine serial number from the 5.0 MPI?
TomZ is offline
Old 08-25-2024 | 04:36 PM
Hello:
1A307152
lg
Old 08-25-2024 | 05:14 PM
The SN comes up correct for that year
SN
AllDodge is offline
Old 08-25-2024 | 11:42 PM
I will change the engines and test it with the 5.0 ECM.
i have Riser with AFR Sonde. So i look at Lambda (Afr).
lg
Old 08-26-2024 | 05:25 AM
You can not use a 5.0 ecu on a 5.7 without reprogramming.
underpsi68 is offline
