Hose question????
Hi all, quick question.
I traded into a 1991 Baja bandit that came without motor and most of the out drive. no big deal I think I got the better end of the deal as to what I traded it for. anyways, today looking it over I saw these 2 hoses and outlets mounted to the transom near the exhaust outlets and am wondering what they were/are for??? is it possible this was one time a dry exhaust and they routed the water through there or am I missing something else? also while we’re at it, I decoded the serial numbers on my outdrive case and accord to what I found it says it’s a Aplha 1 gen 2 drive? surely that’s not factory for a bandit is it? if so how hard would it be to switch everything over to a bravo 1 if I wanted? I included some pics so you all can see what I’m talking about. I circled it in red. thanks https://i.postimg.cc/Hntvgx0n/IMG-8875.jpgprint screen windows xp https://i.postimg.cc/zfRdfpw9/IMG-8876.jpg |
definitly for dry exhaust those 2 hoses !
to switch to bravo, you are going to fill in the transom ( read redo transom) and cut hole for bravo making sure sure X dimension or the height of your drive will be perfectly at the right height to be able to plane, and reach the best top speed possible ! Measure twice... Cut once! |
Thank you sir.
kinda what I figured. im sure as I go along I’m gonna have more questions. again thanks |
are you sure you run an alpha drive? not that many dry exhaust on small block, and i would guess it was a small block because of the drive...
and if you want to use a bravo, i would think you would use a big block, and the exhaust holes won't fit either because of the larger block... |
That’s a bravo transom assy.
The most noticeable difference is the shift linkage on the alpha, It’s not there, just the cable that sticks out of the bell housing on a bravo I had a 91 bandit, cool looking, fast, fun boat, ride wasn’t great unless you were on relatively smooth water, due to the 15* bottom |
According to my serial number off the housing.
the numbers are as follows, https://i.postimg.cc/vm983GYd/IMG-8698.jpg hope you can read that. I get OD491601 it’s off a 1991 Baja bandit. unless it is not original it was added later. and yes I’m going to use a big block. |
Originally Posted by Tom272Baja
(Post 4907156)
surely that’s not factory for a bandit is it? To go from an Alpha to a Bravo I believe you just need buy all the Bravo components. Coupler, transom assy, bell housing etc.. And drill the 2 extra holes for the transom assembly and install. No big deal since the engine is already out. |
I guess I wasn’t aware they ever factory made a small block bandit but I could be wrong.
Here is a picture of an Alpha 1 gen 2 transom assy, notice the shift shaft running down the middle of the exhaust cavity?……. the one on the boat doesn’t have that, it’s a bravo
https://cimg4.ibsrv.net/gimg/www.off...d0b85035c.jpeg |
Ok.
the things you learn. that’s very interesting and makes me happy. so in that case when I do get a out drive for it will any bravo 1 fit or do I look for certain generations/years? |
| All times are GMT -5. The time now is 01:14 AM. |
