My idle counts are 117 as per scan tool now , shouldn't they be around 150 ? Do I adjust throttle stop to achieve more counts ?
IAC count you mean?
In gear or out of ? Out of gear I like 25-35. Open throttle blades to lower count. 150 is maxed out I believe, you`ll probably get that in gear |
you want the counts between 5-10,,so open the throttle blades open till you get that,,then adjust tps to ,5 volts or 0% open.
Originally Posted by articfriends
(Post 4908983)
what tuning program are you using?
| All times are GMT -5. The time now is 11:12 PM. |
