VBelt swap
Old 09-19-2024 | 07:33 AM
Default VBelt swap
1996 502 Magnum, need to change V belt going to raw water pump. Loosened tensioner and belt comes free but cant get it out. Do I have to remove the pulley from the crank or water recirc pump to get the belt out? Seems crazy..There just is not enough space between the crank pulley and the water circ pulley to get VBelt out. Which is easier to remove, the crank pulley or water circ pump pulley? The VBelt to the raw water pump comes off the crank pulley center groove of three. Thanks
Pismo10 is offline
Old 09-19-2024 | 08:04 AM
Active Streak: 30 Days
Water pump pulley. 4 bolts. Put blue lock tight on them when you re-install.
Helmwurst is offline
Old 09-19-2024 | 09:50 AM
Thanks, crazy design.
Pismo10 is offline
Old 09-19-2024 | 12:22 PM
I thought the same thing. They couldn't reduce the pully size by a 1/4"!!! Really!!!!
PQ290Enticer is offline
