-   -   Camshaft Recommendations (https://www.offshoreonly.com/forums/general-q/383967-camshaft-recommendations.html)
jeffswav 10-16-2024 02:49 PM
Who is the best person or company for custom or semi/custom cams?
F-2 Speedy 10-16-2024 03:05 PM
This should be a good as an oil thread......:D....you really need to take in all of the components of the build to spec a cam, in a lot of cases the proven Mercury grinds will work well.
jeffswav 10-16-2024 03:27 PM
[QUOTE=F-2 Speedy;4911696]This should be a good as an oil thread......:D....you really need to take in all of the components of the build to spec a cam, in a lot of cases the proven Mercury grinds will work well.[/QUOT]
Exactly, great way to start off. Not actually looking for advice on cam specs. I know pretty much what I want, been through this before. A lot has changed in the business. I was going to pull up one of my old threads but started fresh this time. If you want to give your 2 cents I will post my specs and what I am looking for.
F-2 Speedy 10-16-2024 04:04 PM
Bullet cams is talked about here, personally Ive not used them, Lunati , TCM in Cali has some off the shelf cams but I dont think they grind them. I had cam motion do a custom grind for some 540's but that was 9 years a go
boostbros 10-16-2024 06:46 PM
i have found bullet by far to be the best to work with they have made a few custom ones for us and they rock, even a reverse rotation big chief supercharged cam
sutphen 30 10-16-2024 07:58 PM
bullet cams for me to,,,they got me stepped nose gen 6 double swap high lift cam cores for a custom grind.
ICDEDPPL 10-16-2024 09:14 PM
Comp Cams and Billy Golds is my go to .
Rookie 10-18-2024 06:14 PM
Comp Cams. They spintron all of their lobes for stability.
Also, never heard a bad word about a Bullet camshaft. I use to run Ultradyne cams before they were bought by Bullet. Now I buy Comp.
CheckmateScarab 10-19-2024 02:33 PM
I've had great experiences with Howard cams. A bit more expensive than a lot of other off the shelf ones but haven't had a bad product
Smitty275 10-20-2024 11:44 AM
Chris Straub in East Tennessee is highly regarded by a lot of builders. I'll be getting my next one from him to try out.
