Why is this plumbed this way? >
Old 01-08-2025 | 07:42 PM
Originally Posted by SkiDoc
I don’t know that it was the head gasket? Do you see something?
On the forensic examination the raw water pump plastic body had a section missing so I think it overheated. Both banks had the same water in them so I don’t think it was an exhaust manifold because I don’t think 2 would fail at one time. I think water got sucked back into the engine from the exhaust. Flappers not working.
not saying this is your problem, but it is a problem
boatnt is offline
Old 01-08-2025 | 09:48 PM
jeff32's Avatar
noticed that too...
jeff32 is offline
Old 01-09-2025 | 02:14 AM
SB
To answer the opening question, click here:
https://www.cpperformance.com/p-7395...for-chevy.aspx
and after reading that, click on the installation instructions on that page.
And there you have it.
SB is online now
Old 01-09-2025 | 04:47 AM
Thanks for the replies, Good find SB makes sense now. Yes didn't even really notice the head gasket not lining up with that water port.
It is a different build. It has 990 GM heads, flat tappet hydraulic cam, 445 block, almost like old school LS7. The numbers on the block say that it could be either 2 or 4 bold main. It has pistons with big domes. I still dont have it pulled because my little tractor won't quite lift over the transom.
I cleaned the cylinders up a bit and surpisingly they look good. I thought for sure it would be trash. I plan to pull the rest and check out what I've got on the bottom end and go from there. I may rebuild a 496 or start from new. The bore is crudely measured at 4.250 with calipers,
SkiDoc is offline
Old 01-11-2025 | 03:34 PM
Got it all disassembled and ready to go to a machine shop. I am going to do a 496 rotating assembly. I haven’t decided whether to use the 990 heads or go with some aluminum ones. I’m going to go to a roller cam though for sure.
SkiDoc is offline
Old 01-11-2025 | 04:08 PM
F-2 Speedy's Avatar
stand that crank up when not in the block.........
F-2 Speedy is offline
