Originally Posted by KAAMA
(Post 4923396)
Griff, would you happen to know/recall what RPM the 500 HP peeked out at with that 731 cam in it?
Thanks The 731 is nearly identical to a 500EFI cam, so I'd guess peak hp around 5300-5400. |
Thanks Griff... With my pair of baby 482cid sized engines both making exactly 510hp each on the dyno at only 5000rpm, then I can only conclude that it's probably because of the Merc Thunderbolt distributors and the Rev Limiter chip it has in it. 🧐
Similar ?
Originally Posted by Rookie
(Post 4917869)
I installed 500 EFI cams in my Merc Gen V 454's a few years ago. I don't regret it. Didn't gain much performance, but the roller piece of mind was worth it.
https://cimg8.ibsrv.net/gimg/www.off...2be411fbb.jpeg don’t know how much similarity there is to the 500 to 525 cams but I have been happy with performance on mine all the way around |
(Post 4923563)
You would know if its hitting a rev limiter. RPM's would bounce 200 rpms or so back and forth at WOT. |
Originally Posted by TomZ
(Post 4917874)
I thought the 731-ish cam that Merc used caused some reversion issues. Maybe I got that one a little wrong?
Had to dig around for the HP 500 specs... courtesy of RMBuilder a way's back: 284*/292* @ .004" 222*/230* @ .050" .576"/.598" valve 110* LSA 105* ICL 115* ECL That 110* LSA probably didn't help much with the Gils that they originally came with. i have listings here, old speedwake, bf’s, and others ??? With all the crane marine hr’s cams. If one can’t find i’ try. |
Heres is 1 of’m
Originally Posted by SB
(Post 4807533)
Merc 500hp is the crane 721 which has 222/230 at .050" with 110lsa
Crane 731 is 226/234 at .050" 112lsa Merc 500 EFI is Crane 230/236 at .050 " with 114LSA Crane 741 is 236/244 at .050" with 112lsa Merc 525EFI is Crane 236/244 at .050" with 114LSA |
Originally Posted by Griff
(Post 4923699)
What Thunderbolts??? TB IV's don't have rev limiters, but TB V's do and are built into the module.
You would know if its hitting a rev limiter. RPM's would bounce 200 rpms or so back and forth at WOT. My 482's were built and dyno tested back in 2008 and have not been run since that time until last Fall. I will have to try to find the dyno sheets but I specifically remember them both being Dyno'd @ EXACTLY 5000rpm each... but I don't recall how the RPM's reacted etc after 5000rpm on the dyno sheets. |
| All times are GMT -5. The time now is 08:21 PM. |
