Puking Coolant
I don't mean to insult anyone's ability, just making a suggestion because it has happened before. Are you sure the head gaskets are on in the correct orientation? The 496 is slightly different in cooling passages from the front to rear of the engine and the gaskets can be installed backwards, causing cooling issues.
Also, how old are the Raylar heads? Early versions did have some issues with cracking.
RAYLAR heads were completely reworked with no cracks. Per the machine shop. You would think they would inform me. They have been doing our machining for 30 years.
Do you know anyone at an automotive shop that might have a combustion gas tester ? If not they are not that expensive and it would be easy to see if it is a head gasket leaking combustion gas into the cooling system.
https://www.harborfreight.com/combus...tor-64814.html
Another alternative would be to use a radiator pressure tester but I dont know what your cap is like and if there would be an adapter available to fit.
From the symptoms you are describing it almost has to be a head gasket.
