Cam only MPI 383? >
Cam only MPI 383?
Cam only MPI 383?
Old 03-05-2025 | 04:14 PM
Simply offered as an FYI reference, I have been using a 221/230 @ .525/.545" on a 114 LSA hyd roller cam in a 377 (Crower cam) with no reversion issues. In my estimation this cam is near, but not at the limits for stock wet exhaust in a SBC.
Trash is offline
Old 03-05-2025 | 06:39 PM
Originally Posted by sutphen 30
then....... its a 3/4 race cam for you.
Hell yeah! Will that make my boat jump a Coke can?! 🤣
Danl_ftw is offline
Old 03-05-2025 | 06:44 PM
Originally Posted by TomZ
As Trash mentioned above - not worth it.
Enjoy it for what it is.
Honestly, I had planned on swapping an L92 in. But the LS swap community agreed that the 383 is an excellent marine engine, so I thought I’d explore options for getting more out of what I have. I know how quickly a build can rack up a bill, so I really wanted to leave the rest of the valvetrain alone, if at all possible. There are also some cost friendly aluminum heads local to me, but I have no idea how much the machine shop bill would be to marinize them.
If in the end there’s no way to do it without dropping massive amounts, then perhaps a custom calibration would be the only thing I’d do in order to make sure it’s running its best.
Danl_ftw is offline
Old 03-05-2025 | 09:52 PM
SB
383 Mag’s don't come new in boats but are available ‘over the counter’ . It is from Mercruiser.
Anyone know the cam specs / valve train specs ? All i can find mentioned is roller rockers.
SB is offline
Old 03-06-2025 | 10:29 AM
I know most of the 350's came with that GM 395 cam (288 int./308 exh,, 0.431 int./0.451 exh., 109 LSA , and the 377 Scorpion had the 222/230 .510/.530 114 LSA. The cam for the 383 MPI likely falls somewhere in between these two. I can't find the part number but it is possibly around these specs Cam Specs: 215/220 @50 .457in/.474ex 112LSA
Trash is offline
Old 03-06-2025 | 10:45 AM
Small block chevys don't make any power in marine applications. You're just wasting your time.....
94sylvan is offline
Old 03-06-2025 | 11:57 AM
Not sensing sarcasm, but if you are looking for 400 ish HP SBC will do the job. More than that gets problematic if naturally aspirated.
Trash is offline
Old 03-06-2025 | 12:56 PM
Trash,
The sarcasm skipped past you then... Do a search of OSO with my username if you want some marine SBC tech.
94sylvan is offline
Old 03-06-2025 | 04:03 PM
Nonsense. Sounds like a friend of mine who swears it’s big block or nothing. I smoked him with a naturally aspirated 346” LS.
My boat came with a 350. The 383 is plenty for it, even if I leave it alone.
Danl_ftw is offline
Old 03-06-2025 | 04:25 PM
If you didn't pick up on the sarcasm, you might want to check out this thread.
High powered small block alpha
94sylvan is offline
