502 MerCruiser MPI head and cylinder issues >
Old 03-16-2025 | 07:31 PM
  #41
Originally Posted by sutphen 30
pull some top rings and look at the ends,,see if they are shiny.
Will look
Scarab2969 is offline
Old 03-16-2025 | 11:38 PM
  #42
Originally Posted by BillK
I was just looking at the pictures again and find it strange that the wear on the cylinders is to the front and back of the engine. Usually if pistons are too tight it will be on the sides where the skirts are. Have to wonder if the rings arent butting.
Do you have an itemized list of the parts they used ?
Piston. Icon .064
Piston Rings Mahle Part # MAH-3150108035 Summit Racing
Old 03-17-2025 | 05:40 AM
  #43
Originally Posted by Scarab2969
Piston. Icon .064
Those should be correct but they are definitely file fit rings. You should be able to look at the ends of the rings and see if they were butting up against each other. They will be shiny if they were.
According to the KB catalog the piston to wall clearance should be between .0055" and .007" and the top ring gap of .018"
BillK is offline
Old 03-17-2025 | 07:55 AM
  #44
Awesome. Thanks so much.
Old 03-20-2025 | 01:05 PM
  #45
articfriends's Avatar
Stack cam, compression was 155 after rebuild now all cylinders dropped 20 to 25 since this has been happening.
stock tune on ecm?
articfriends is offline
Old 03-20-2025 | 01:08 PM
  #46
Originally Posted by articfriends
stock tune on ecm?
as far as I know, I’ve never done anything with the ECM. I don’t even know who would tune an ECM.
Old 03-20-2025 | 01:13 PM
  #47
F-2 Speedy's Avatar
I think the question was asked but did you put the ECM in base timing mode before you set the 8* of timing ? then its removed from base time mode to allow the ecm to take over
F-2 Speedy is offline
Old 03-20-2025 | 01:25 PM
  #48
yes, I did set the base mode maybe at 10, but I would think that would make that much difference but I guess it could have. Would 2° make that much detonation difference?
