Looking for guidance - Bravo 1 maintenance
Hello All,
Looking for guidance and help. One question I have is, is it better to buy the parts separate or buy the bravo kit. Looks like the kit is more expensive and if you buy separate it seems to be cheaper. I am looking to use only Mercruiser parts The drives are pretty current and look good but if I find something wrong I will replace it. Drives have about 40 hours on them from previous owner. Just trying to buy the things I know I will need ahead of time to minimize down time. I am getting ready to do some maintenance on my outdrives. I have Bravo 1 and I am looking to do the following:
Thanks in advance for any help |
Why do you want to or think you have to separate the upper and lower units????
Bajaman
the hole that the yellow fitting goes in is extremely loose. When looking at the exploded view I see there is a seal. since the drives will be empty of no fluid, I figured now is the time to install it. I don’t use the Speedo but I like to have everything working. I just hope I’m not opening scan worm by separating the lower unit |
If you aren’t sure how old your bellows are just replace them - U-joint and shift cable. don’t forget Bellows adhesive. Broken Bellows can sink a boat if you’re unlucky. ONlY use OEM - trust a guy who got screwed on this point.
make sure you buy fresh fiber washers for the fluid drain plugs. Make sure you get the old one OUT. there is a 75% chance that if you have drive lube reservoirs they are “gunked up” in the bottom and need to be removed and cleaned. Lower cables are often corroded in the bell housing and have to be drilled out. You’ll need the alignment tool to hook them back up. Buy on eBay for like 5bucks. I’ve always just cut a slit in a paint stirrer for the shift cable tool that goes on the face of the bell housing which has worked well. im not any help on splitting the bravo for the Speedo seal you’re talking about because I have GPS speedo (which doesn’t work) Lube splines when you reassemble on both the prop and drive shaft. Don’t use TOOmuch on the driveshaft spline because it can build up in the flywheel and it doesn’t compress real well. Check your gimbal bearing when you have the drive off. |
Originally Posted by Priobe
(Post 4924559)
Bajaman
Seafordguy
Thanks for all the advice you provided. You answered questions I did not even ask but was now thinking, thanks again. I was planning on buy the alignment tool. I already have the tool to install the gimbal ring, and the shaft to install it. I had to purchase the alignment tool. Are there any other special tools I am missing? |
Bajaman
The oring I am suspecting is missing or broken is in the picture below #5. This is a twin motor setup and the other drive has a yellow fitting and fits snug. The drive I’m speaking about is loose. When installing the fitting it is not snug like the port drive. Instead when installing the fitting in the starboard drive it kind of just falls in the hole. I’m not sure I 100% understand your post. I think you are saying the o ring is on the yellow fitting itself. The oring I’m speaking about is in the picture #5 Also, I’ve never separated B1 and not sure if you are indicating that I don’t have to separate the unit. Also was going to order 3 for a good proper seal. im sorry can you clarify your post https://cimg9.ibsrv.net/gimg/www.off...d010465b58.png thank you and thanks to all that are replying. |
It is called a seal but really a bushing
The yellow plastic adapter (Item 16) has a O-ring which is not shown which seals the Speed-o tube https://www.hardin-marine.com/p-6568...r-815303t.aspx |
AllDodge,
I think I understand, but I swopped the yellow fitting from the port drive to the starboard drive and it is still loose. I placed the starboard yellow fitting into the port drive and it is tight. This is why I am thinking its the #5 seal/ bushing that must be missing. I hope this helps clear up as to why I think its something in the drive or am I missing something? |
Drives have about 40 hours on them from previous owner. The good thing is a Bravo is easy to split and reinstall. Not like the Alpha which needs the upper shift foot and lower shift shaft synced before joining together. The Bravo just slides back together and only a couple O-rings. So if you want to put it back in, all good |
| All times are GMT -5. The time now is 11:10 PM. |
