Mercruiser water pressure relief valve or CP performance
I need to install water pressure relief valves
Trying to decide between Merc 863208A3 which is about 500.00
or CP performance 128-5000/5002 with 1285001 tee cost about 140.00
Is there any advantage in using the Merc part vs the CP performance part given it will equate to a 700.00 difference in cost for both motors
I installed the mercury valve when i put a Imco lower unit on. Had too much pressure. Then my pressure would swing wildly like from 10 to over 30 lbs. I even changed the spring to less tension. Put the CP 3/4 valve in works great!
how about thoughts on the psi setting
500efi raw water cooled xr drives with low water pick ups
25 or 30 psi max?
they were pegging the gauge at 35
25 or 30 psi max?
the mercury one works awesome. use it after oil cooler. The nice thing about it being on the "push" side of the pump is no risk of it sticking and sucking air.
The downside- the merc racing pressure relief valve is soon to be NLA.
