Originally Posted by Griff
(Post 4925965)
I'd get one starting and one deep cycle. They are designed for different purposes. I run a starting battery for each engine and have a deep cycle for my stereo. I always run Interstates. Mine usually last 7-9 years. No tender on them and I charge them every couple months in the off season.
Cranking Battery vs. Deep Cycle Marine Battery |
Originally Posted by xlint89
(Post 4925988)
Can you charge them both simultaneously from the alternator? You know, the battery switch. 1, 2 or both? https://www.cpperformance.com/p-8027...4-pos-afd.aspx
Throwing this out there, but there are a ton of great Chinese lithium batteries on Amazon. Fraction of the weight, about the same price, and will last you much much longer than standard lead or AGM
Only issue is you may need a DC to DC charger depending on your alternator All batteries are made by one of 3 manufacturers, X2 is most likely the best you will find, better than optima and odyssey as they are both declining |
Originally Posted by CheckmateScarab
(Post 4926022)
Only issue is you may need a DC to DC charger depending on your alternator All batteries are made by one of 3 manufacturers, X2 is most likely the best you will find, better than optima and odyssey as they are both declining I appreciate everyone’s feedback so far, thank you! |
I don't think you can do better than the dual-purpose AGMs from West Marine. I get 6 years minimum from them, regardless of what they're asked to do. But, they're not cheap.
As a bonus the AGMs are a lot less sensitive to shock and vibration damage. I've tried. I switched to AGMs exclusively years ago after experiencing internal breakage on a few wet cell Interstate starting batteries (1000MCA) after hitting wakes. My wife was stranded just last summer from a wet cell breaking internally on her 2023 jet ski. The higher the MCA rating the more likely that happens due to the thin plates. |
As mentioned above I would highly recommend the 3 position switch route. I run two deep cycles in my boat and they crank a big block just fine. Also installed a min Kota in board charger with a flip up cover so I can easily plug the charger in without having to get in the boat.
| All times are GMT -5. The time now is 09:38 AM. |
