Velocity 390 Purchase Opinion >
Old 05-12-2025 | 02:17 PM
Originally Posted by jeff32
Double !!! Really?
wow
i did not expect that !
what would it cost just to strip the engine bay for the work?
Then replace it all, maybe making some upgrades along the way on the rigging etc.
Tartilla is online now
Old 05-12-2025 | 02:43 PM
F-2 Speedy's Avatar
Engine bay looks pretty good and tidy.....good luck with the purchase
F-2 Speedy is offline
Old 05-12-2025 | 03:57 PM
Love those boats. And it looks clean. Price is fair. But a transom could put you upside down it. Only hurts once though, then enjoy it for 5-10 years.
hogie roll is offline
Old 05-12-2025 | 07:32 PM
Originally Posted by wally649
Hello everyone. I'm about to pull the trigger on a 2000 Velocity 390 with HP500 and Bravo 1 drives.
I had a boat survey done everything with Hull checks out with 1 note that I may be over thinking.
Transom moisture reading "med to high" at different spots in the transom but inspection guy said
" the boat is 25 years old and its normal. It is indicating there is med to high moisture in the wood coring of the transom. All hammer percussion soundings were good."
The boat mechanically ran fine. Think needs bigger props...has 26p Bravo Props.
Seller asking 59k, inspection guy valued it at 54k. Should I close on this deal? I'm flying up to Florida to see boat in person on Tuesday.
If im correct i looked at that boat last year. Pompano beach. it was in decent shape. i had the same readings around the transom assembly and exhaust. there was a hanging piece of rotted wood in the cabin above the bed. Id guess it could of been from the anchor locker. starboard rear corner of the rub rail looked like someone backed into a wall or something and tried to fix it with caulk. these are all small issues to me Except the wet transom, thats why I didnt pull the trigger. Im in no way trying to talk you out of it, just want to give you a heads up and things i saw for you to look at.
Msilesky1 is offline
Old 05-12-2025 | 09:26 PM
Sent you a PM
wally649 is offline
Old 05-12-2025 | 09:32 PM
apparently i dont have enough posts to reply to it
i need 10 this is 4
Old 05-12-2025 | 09:33 PM
and 5
and six
Old 05-12-2025 | 09:34 PM
and 7
