2014 Bravo 3 outdrive prop shaft torque on retainer ring >
Old 05-15-2025 | 10:15 AM
Default 2014 Bravo 3 outdrive prop shaft torque on retainer ring
Hello
I have a 2014 Bravo 3 outdrive, I pulled my props and the sel retainer off in the process of trying to reinstall it, and I found that the retainer ring that holds the bearing race for the prop shaft in place was loose. I have ordered the special tool to tighten it back up. But I can't find the torque spec on that retaining ring? and any suggestions on tightening into the proper setting.
I know the large seal retainer has a torque spec of 130'lbs. plus adjusted for the offsetting of the tool and torque wrench. But this is the retaining ring in front of that.
Any help is appreciated.
Whiskey is offline
Old 05-15-2025 | 03:57 PM
german torque,,goodintight.lol
sutphen 30 is offline
