Quicksilver 85 90 extreme gear oil >
Old 06-22-2025 | 05:33 AM
The simplest solution here is to just get some virgin Merc lube tested.
See if it's any good.
There may even be some posted analysis for the merc oil floating around the net.
Tartilla is offline
Old 06-22-2025 | 12:12 PM
To Dan's point I guess it comes down to preference, I've always run Mercury, I just had a drive rebuilt and if I choose to go to another oil besides what my drive guy uses / recommends........I have no warranty
out of curiosity how many hours did you have on your drive and did you see flakes in the oil or have a failure
if i remember correctly you are around 750 hp
Rons1 is offline
Old 06-22-2025 | 12:27 PM
F-2 Speedy's Avatar
Ron, I had a failure Im no drive expert but Doug is, he's not sure my it failed possible prop strike ? I dont run my stuff hard just cruising along about 65 and boom, tore the steel tower out of the housing and even broke the shift cable.
F-2 Speedy is offline
Old 06-22-2025 | 08:20 PM
Doug K from ROTO?
I told him I`m not running that watery mercury junk and he was fine with it .
ICDEDPPL is offline
Old 06-24-2025 | 10:52 AM
Make no difference unless you are running a huge engine on a heavy boat. Any heavy oil will do.
Pismo10 is offline
