Mefi 3 vs Mefi 4 >
Mefi 3 vs Mefi 4
Mefi 3 vs Mefi 4
Old 07-10-2025 | 01:07 PM
Default Mefi 3 vs Mefi 4
What is the easiest way to tell if the engine harness I have is a Mefi 3 or Mefi 4? I don't want to plug my Mefi3 in and fry it.
800XCR is offline
Old 07-10-2025 | 01:45 PM
F-2 Speedy's Avatar
I dont think there is a difference or two different harnesses
F-2 Speedy is offline
Old 07-10-2025 | 04:53 PM
articfriends's Avatar
a mefi 4 harness is Definitely different then a mefi 3, now a mefi4, 4a and 4b use same harness.
articfriends is offline
Old 07-10-2025 | 05:01 PM
F-2 Speedy's Avatar
Well Smitty learn something every day, does power and ground go in on the same pins on a 3 vs 4 ?
Old 07-10-2025 | 05:11 PM
so if you open both these, take a look at j connector legend, the mefi3 one is on page 7-24 to 7-27 and tells you color of wire in the j connector cavitys, you can compare it to yours
472681_MEFI-4-8.1.pdf
https://marinepowerusa.com/wp-conten....2L-502CID.pdf
Old 07-10-2025 | 08:27 PM
Attachment 577908
Thank You!
800XCR is offline
