Mercruiser unavailable hose
I knew this would come up one day. Looking for a Mercruiser oem hose 32-816285. Outlet of seawater pump to inlet of oil / power steering cooler at back of engine. Does anyone has any of these laying around.. Alternative, make one with a wired shields hose.Trying to find a oem molded hose instead. Pic attached
What size hose is it ? I would go to a local auto parts store and see if they will let you look through their hose inventory. You might be able to find something close enough to work. I dont know if Gates or Goodyear have an online catalog that shows all of their hoses. Might want to look for that also.
FWIW, I just bought a hose for the same routing, sea pump to trans cooler, on my 350 MPI, so it is possible that might work for you as well. The part number was 32-8080441.
If you want, I can send you the old hose for just the cost of shipping, to see if that will work for your application.
https://www.marineengine.com/parts/m...irculation.htm
That's not a good part number - I know it doesn't make sense but Mercury does not put the actual number on the part.
See https://www.mercruiserparts.com/why-...ed-or-received
Do you have the engine serial number?
Marc
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Mercury-Mercruiser 32-816285 HOSE, OIL COOLER TO SEA PUMP - OLD DESIGN
- Home /
- Mercury-Mercruiser 32-816285 HOSE, OIL COOLER TO SEA
- Typo in the number, but its still unavailable
Try Sea Way in seattle 425-412-4006
and ALMARS OUTBOARDS INC 302-328-8541
One of them might have it. Tell them we sent you.
Marc
www.go-fast.com
www.bammarine.com
Marc
www.go-fast.com
www.bammarine.com
