502 flywheel ring gear >
Old 08-06-2025 | 02:59 PM
Default 502 flywheel ring gear
The ring gear on my 502 flywheel is loosing some of its teeth. Can I assume that a ring gear for the same size GM flywheel - (assuming it’s a 168 tooth gear ) will work just fine or do I need to pay the boat tax? Pulling the motor in and out sucks.
carnutsx2 is offline
Old 08-06-2025 | 03:17 PM
Any GM 168 tooth ring gear will work. Summit has them for under $20.00.
GF?
Got Freedom? is offline
Old 08-07-2025 | 01:13 AM
GF?
GF?
Old 08-07-2025 | 06:32 AM
GF = Got Freedom.
his handle
Tom272Baja is offline
Old 08-07-2025 | 11:32 AM
Ayuh,...... You can just knock it off with a punch, flip it over, 'n reinstall the same gear,....
Going back on, heat in yer oven, 'n it'll fall into place,.....
Bondo is offline
Old 08-07-2025 | 08:04 PM
Got a new one on the way, let the party begin. Anyone have any tips on setting up the alignment?
Old 08-08-2025 | 11:49 AM
engine or starter?
sutphen 30 is offline
Old 08-08-2025 | 05:08 PM
Originally Posted by sutphen 30
engine or starter?
alignment of the engine to the outdrive.
Old 08-08-2025 | 05:49 PM
You will need an eng alignment tool to align eng to outdrive via the gimble bearing. They are fairly cheap online. Highly recommend picking up a tube of Merc spline grease for the outdrive input shaft (and alignment tool). 1 tube will last you basically forever.
Before re-installing eng and before re-installing bell housing, mount the starter and engage solenoid to verify it's aligned properly so new flywheel teeth don't get chipped. With bell housing removed, you will have a front row seat to the starter/flywheel engagement and can easily take measurements/make adjustments.
Verify the starter bolt knurling is the correct size, otherwise the starter can move around and mess-up the alignment with the flywheel teeth. If everything is orig, you should be OK. However, I've experience mini-starters that needed "stepped knurling" on the starter bolts.
If you find 2 large fiber washers and 2 really short springs laying in the bilge after removing the eng, hang on to them. They will be needed going back in.
zz28zz is offline
