Temp gauge issues
Hey guys, I changed all my gauges out from the stock livorsi to autometer pro comp marine. (That look awesome BTW) I am now having trouble with the temp gauge. It was reading high on my first trip out but no alarm. It was pretty consistently reading around 210 but I used an infrared thermometer and temps were reading well below that, (in the 170 range) so I thought it could be that the original temp sender was not compatible with the new gauge so I ordered the autometer temp sender. It has a single pin for a one wire connection. I changed that out and gauge still reading 210. I tried unplugging the wire off the sender and no change on the gauge, still reading 210 even with the wire off. I then unplugged the other sending unit that is a two wire connector with an actual plug. When I unplugged that one the alarm went off and gauge went to 0. I thought that the sender with one wire was for the gauge and the two wire sender was for the ECU/ECM. What is the sender with one wire for and do I have something screwy going on. Any insight would be much appreciated on what is actually going on
thanks in advance
Seth
thanks in advance
Seth
Single connector temp gauge sending units are just sinple thermistors. The resistance chamges with temperature. They have charts on temp and resistance. Use a multimter to check the resistance of the sending unit, confirm it's correct.
If your gauge wiring has any extra resistance anywhere, it will skew the gauge readings.
https://www.autometer.com/sensor_specs
