Help picking stud girdles
So I'm in the market for stud girdles and yes I know shaft rockers are the answer but not making that jump yet...anyway...I see a lot or most girdles call out a specific head being brodix or dart or whatever and I am running iron enginequest heads. I will include the spec sheet here and I'm looking to try and get some info on which "name brand" head is compatible with mine to get a set of girdles. Thanks for the help!
Microsoft Word - Chevy Cylinder Head EQ-CH454A.doc
That's what I'm trying to figure on is the "configuration"....is there anywhere out there I can find measurements or anything to determine which configuration I need? Dart, Brodix, "standard"? Those look great and will def give them a look!!
I thought the Enginequest heads were supposed to be stock GM dimensions ? Call EQ and ask them ? That is the first thing I would do.
That being said I have had good luck with Comp's stud girdles for many years. How big of a cam are you running that you think you need them ? Spring pressures ?
Sorry had a crazy weekend couldn't get on...Don't remember exact lift numbers and spring numbers but I know the cam is right around 680 lift hydraulic roller. It's a 540 with around 7 lbs out of a 14-71 fuel injected. Planning on running it up to 6k....I probably don't "need" them but while the motor is out and as cheap as there really I figure why not...would rather have them and not need them than wish I would have done it.
F2....I called webster...great dudes btw! The guy that answered the phone was not familiar with these heads but was going to consult with the owner of the place and get back to me....haven't heard back yet.
Bill....I thought the same thing but don't know how to verify that without just buying a bunch and trying them?? I do know the exhaust ports are raised .500 but not sure if that affects anything with valve placement or not?
Me overthinking as usual but calling them is probably the best way to go....figured I'd throw it out on here to see if anyone knew offhand
I could tell you a conversation I had with Brad Smith ( Smith Power ) what happened on back to back dyno pulls on a big cube SBC with & without stud girdles..........but you wouldn't believe me......so dont run them they are not needed
But if you like more trouble with no benefits you should definitely geta few sets !!
1. More hassle during valve adjustment
- You can’t just throw a feeler gauge in and tweak a polylock like normal. The girdle clamps across multiple rockers, so you often have to loosen the girdle, adjust, then re-tighten it. That makes valve lash adjustments more time-consuming.
- Some designs require shimming or clearancing to get everything lined up.
- A stud girdle ties all the rockers together, which can transmit valvetrain harmonics. Sometimes it makes the engine noisier.
- They raise the effective height of the valvetrain. That can cause clearance problems with tall valve covers, baffles, and breathers. Often you need tall covers or spacers.
- If you’re not spinning past ~6,500+ rpm or running really high spring pressures, the stud girdle doesn’t add much benefit. On mild builds, it’s extra complexity for no real gain.
- A stud girdle helps control stud flex, but it doesn’t fix weak rocker studs or pushrod deflection. In some cases, people use one as a “band-aid” instead of upgrading to a shaft rocker system, which is stronger and more stable.
- Not huge, but it does add mass to the valvetrain, which can increase harmonics at certain frequencies.
Great for high-RPM or aggressive cam/spring setups where stud flex is a problem, but for a street/mild performance BBC, the downside is mostly added hassle, clearance issues, and not much payoff.
Sorry , not sorry.
