Valve cover condensation  problem >
Old 10-18-2025 | 07:29 AM
Originally Posted by tripps
It's a fresh 502 w hp500 cam I'll try for temp I pan w temp gauge I don't r Un it for long time I know it's gotta run hotter
I'm assuming the cam is the hp500 efi cam?
sutphen 30 is offline
Old 10-18-2025 | 12:36 PM
I wonder too, since the carb HP500 cam is prone to reversion at idle rpms
Griff is offline
Old 10-19-2025 | 09:25 AM
tripps's Avatar
Think efi cam don't idle it alot just put a 2 inch pulley on waterpump to slow it down and restrict or in thermo housinng
tripps is offline
Old 11-21-2025 | 07:18 PM
tripps's Avatar
Default Condensation
OK I ran motort to 140 and condensation I s gone restricted water at hose now it's all gone. Or was it from sitting a Mon t h ?
tripps is offline
Old 11-22-2025 | 12:55 PM
seafordguy's Avatar
I think a question here is how much condensation? I always has a bit on my motors in my Cafe - bypass and no stats. I screwed around with restricutors, etc, but finally just gave up. It wasn’t like I was getting to the end of the season and my oil was watered down/milky, there was just always some condensation under the valve covers and on the bottom of the breathers…..
seafordguy is offline
Old 11-22-2025 | 04:04 PM
I run a closed cooling system(engine only, love my aluminum heads) 160 thermostat and she runs 160-170, I have a very large oil cooler and it runs 200ish and it seems to burn of the condensation no problem, I imagine that after I shut her down overnite there probably is some but seems too burn off/evaporate after a good long run, you should try an oil temp gauge very handy to keep an eye on temps.
496blower is offline
Old 11-23-2025 | 12:53 AM
Got some under covers motor runs 125 don't have bypass on manifold or bypass ,how about t I disconnect oil cooler to get oil temp up or do I need water temp up to get rid of condensation .I have a merc waterpump ran off crank pulley? Tia
125 is too cool. Heat builds power. That's not uncommon and the only place you'll see it is likely under valve covers of a boat. You should be venting your engine and running catch cans. Often it's because of pulling valve. Overs within an hour of running. I've had engines it disappeared over nite.
boattrubador is offline
Old 11-23-2025 | 07:34 PM
tripps's Avatar
Default Cond
Thanks guys
tripps is offline
