Compression test
Just bought a new boat and I am wondering if there is a way to have an idea on compression test to CR.
Motors are rebuilt HP500EFI’s and all cylinders were 160 cold/ 165 warm. That is more then my stock 500’s, granted the last time I did it was at 600ish hours. The reason I wonder is during the sea trial I hit 5400 pretty easy and am spinning stock 34 bravo’s with 1.5 drives. That is above the stock rpm limit and a lot more prop. Cannot get a hold of engine builder, long story but when I had my shop check them out they said all gauges matched the computer. Kind of rare on these things. |
What'd you buy?
I always heard/read that there's no easy way to go from psi to CR, because there's so many variables.... Cam timing, for one. |
Yeah trying to figure out what gas I need to run.
90 rec is easy, higher is a PITA since all on water is 90. 35/twin step https://cimg2.ibsrv.net/gimg/www.off...c67e7c1d5.jpeg / side by side |
sweet! So the 32 going up for sale?
Yup it's s pita to get great fuel at the docks
around here all the Murphys have non ethanol 91 Works very well That boat is very good eye candy |
Good looking boat !
This is what Grok says: for a stock Mercury 500 EFI (502-cid / 8.2 L V-8) there are published “compression pressure” numbers.
Of course “real-world” compression tests of used 502s tend to run a bit lower (often “over 150 psi” is cited as “acceptable” in marine owner/forum discussions). ChatGTP: Yes, you can estimate the compression ratio (CR) of your Mercury 500 EFI (502 CID / 8.2L V8) from a cranking compression test reading of 165 PSI, but it's an approximation only. Cranking compression depends on factors like cam timing, valve condition, ring seal, cranking speed, and manifold pressure during the test (typically wide-open throttle for a fair reading). It doesn't directly measure static CR but correlates roughly via the polytropic compression process for air-fuel mixture. Stock Specs for ReferenceFor context, the Mercury Racing HP500 EFI has a stock static compression ratio of 8.75:1 (bore 4.47 in, stroke 4.00 in). A healthy example typically shows 190–210 PSI across cylinders when tested properly (wide-open throttle, fully charged battery for consistent cranking speed).Your 165 PSI reading is on the low side, suggesting potential wear (e.g., rings, valves) or a conservative test method, which would equate to a lower effective CR. |
How to Calculate CR from PSI (Step-by-Step)Use this common approximation formula for gasoline engines during cranking (assumes sea-level atmospheric pressure of 14.7 PSI, polytropic exponent γ ≈ 1.3 for air-fuel mix, and 90% volumetric efficiency/leakage factor to account for real-world losses):Gauge PSI = [(CR^γ × 14.7) - 14.7] × 0.9 To reverse it for CR given your PSI:
Quick Comparison TableCompression Ratio Expected Cranking PSI (approx.) Notes 7.4:1 (your est.) ~165 PSI Matches your reading; possible wear. 8.75:1 (stock) ~190–210 PSI Healthy baseline for this engine. 9.5:1 ~200–220 PSI Higher-tune variant; less common in marine apps.Recommendations
My brain chat (it talks/mumbles to itself :) ) older person real experience says165-175 across the board is healthy 8.75:1 502 cid motor. :)
That Ai referred to above doesn’t know any better that to get 200-210 cranking compression needs a solid 10.5:1 compression ratio to get there. |
If your shop has a bore scope they should be able to look in the cylinder and see what piston is in it. That and the cylinder head casting number should get you pretty darn close.
Previous owner cant tell you ? If you know who the engine builder is I would keep trying with him also. |
I wouldnt worry so much about your "compression". most 500s test about 150 to 160. It sounds like your concern is what OCTANE you can get away with. Hers a REALLY simple test, verify base timing is at 8 degrees in service mode, throw timing gun and distributor wrench in the boat, then fill boat up with 89, plug a pair of rinda tech mates in, go out at watch for KR thruout the throttle range, deliberately undertrim the boat so it sorta "lugs", if you have NO KR, your golden on 89 and up. IF you want to "find" the threshold of KR, bump base timing up to 10 degrees which essentially "overtimes it" by 2 degrees, about how much timing I like to be from KR if my dyno and boat LIKES the timing. You start seeing traces of KR here and there, your close, if not you could go a step further and try 87. Your boat should NEVER show constant KR at wot, IF it does you need MORE octane, less timing or injectpr service etc.
| All times are GMT -5. The time now is 10:06 AM. |
