-   -   1988 Chris Craft Catalina 426 engine question (https://www.offshoreonly.com/forums/general-q/387300-1988-chris-craft-catalina-426-engine-question.html)
TreSea 01-24-2026 03:43 PM
Good afternoon I have a 1988 Chris Craft Catalina 426. Crusader 454's. I have been swapping Tachs out. Now working on an old engine sync. Does anyone know what this box does?
thanks Tony
https://cimg4.ibsrv.net/gimg/www.off...80e5aaa686.jpg
boostbros 01-24-2026 08:57 PM
put delco est ignition kits in it will run much better and improve milage its a big change much smoother idle thats why we use so many on fishing boats they idle with a lot of timing smoothing out drive train
TreSea 01-25-2026 06:00 AM
Thanks. But the question was what does this box do?
I believe it is only there for the engine sync?
Ryanw10 01-25-2026 06:24 AM
That looks like it is for your engine sync gauge
compedgemarine 01-25-2026 07:20 AM
it looks like maybe this kit.
https://www.onwatershop.com/product/...chronizer-kit/
if so then you should have the control box that turns it on and off and tells you what each engine is doing then it lets you get them together in rpm. if it works, great but if not I would just take it out and either get something more modern or do away with it and listen and feel the rhythm of the engines.
powerboatr 01-25-2026 09:30 AM
My liberator has 1988 sync guage
it is pretty analog
The needle sweeps towards engine turing more rpms
imo its not very informative
both tachs are now digital
Its pretty easy see wgich engine is turning more
I thought it worked like old vacum gauges,
But it takes a signal from tachs input
My splitter panel looks alor like yours
if it warms up
I will get a pic
TreSea 01-25-2026 11:04 AM
Yep. That's what I have. The head unit is bad on the sync. I'll probably remove the box in the first picture and start fresh. Thanks
