Imco and Mayfair Hydraulic steering
Hello, Im working on my boat and it has imco hydraulic steering rams. I don’t have the outer clevis that mount between the ram and the drive cap. I have a Mayfair ram with the clevis still on it and thinking if I could use that one.
Does anyone know if they are the same? Or if someone can measure a imco clevis so I can compare with mine. They do look the same but hard to tell by photos. imco part number: 421-05-1034 mayfair part number: 137-9225 |
I can measure my IMCO ones this evening
Naturally my battery is dead, but measurements are here:
https://cimg7.ibsrv.net/gimg/www.off...f464336676.jpg https://cimg8.ibsrv.net/gimg/www.off...33eea08f4a.jpg https://cimg0.ibsrv.net/gimg/www.off...730a10ef86.jpg https://cimg3.ibsrv.net/gimg/www.off...911da2dce5.jpg |
Originally Posted by CheckmateScarab
(Post 4943961)
Yea it looks like the pin will fit the steering cap but the thru-bolt on the ram has a different dimension. 1/2" vs .0.68". I'm sure you could shim and add some washers to cover the difference in a pinch
| All times are GMT -5. The time now is 07:10 AM. |
